2004 BMW 320 won't start
2004 BMW 320
86,020 MILES • 6 CYL • 2WD • MANUAL
SMOKESCREEN33
won't start...battery checked good...mechanic replaced temperature sensor...and thermostat...car started...wouldn't start...wont even tuyrn over...what could be the problem
Dec 31, 2009 at 3:51 PM
No crank at all/nothing/nada:
Could be the starter, starter relay, park and neutral switch,clutch switch and ignition switch assuming the battery and connections are good.
Jan 1, 2010 at 3:07 AM
DOCHAGERTY
  • 9,606 POSTS
It could also be a mis-alignment of the EWS system, if so then a trip to your BMW mechanic may be in order.
Jan 1, 2010 at 9:51 AM
