2001 BMW 320 DOORS LOCKED
125,000 MILES • 4 CYL • 2WD • MANUAL
ALANPERDISATT
I LOCKED MY CAR TODAY AND I CANT OPEN IT,THE REMOTE WONT WORK AND THE KEY WONT WORK MANUALLY IN THE DOORS EITHER,I COULD ONLY OPEN THE BOOT AND BOOST THE BATTERY TO SEE IF THAT WOULD WORK BUT IT DIDNT,CANT FIQURE IT OUT,ANY HELP WOULD BE GREAT,,,,THANKS
Jan 31, 2010 at 11:47 AM
DAYCLONE
  • 16 POSTS
You should be able to open the door manually.
It could also be that the battery is completely dead, and that there is no signal in which case you could open the trunk manually too, to charge the battery, but I'd check the battery with a volt meter first to ensure that it either is the batter or not.
If this doesn't work then you'd need to call a locksmith to open your vehicle and determine if the battery is kaput or not.
Now, if all is well and your driver door still doesn't unlock it could mean that its the actuator or if its not that then your GM5 Module that controls the locking system which is also known as your ZKE module.
For more info on that module please visit: www.bmwgm5.com
Goodluck!
Feb 20, 2010 at 6:09 PM
