2000 BMW 320 Warning light
2000 BMW 320
93,000 MILES • 6 CYL • 2WD • MANUAL
PHIL.D
Could anybody explain what the amber oil can warning light refers to. This light appers for about 15 seconds after starting the engine.The engine has no leaks and has recently had a oil change. There is also a problem with engine stalling on or around idle speed when engine is first started, once engine is warm no problem or perceived
Sep 8, 2010 at 9:38 AM
DOCHAGERTY
  • 9,606 POSTS
The thermal oil level sensor is setting the yellow oil can on, ignore it. The stalling is possibly due to a tear in the air boot from the air mass to the throttle body. #14 in this link for the oil level sensor: http://www.realoem.com/bmw/showparts.do?model=AV13&mospid=47717&btnr=11_2187&hg=11&fg=10
Boot is in this link: http://www.realoem.com/bmw/showparts.do?model=AV13&mospid=47717&btnr=13_0905&hg=13&fg=15
Sep 8, 2010 at 1:52 PM
