1990 BMW 320
HUGOG
Electrical problem
1990 BMW 320 6 cyl Manual
Has problems starting .Will crank but will not start -sometimes only after a couple of cranks This happenes mostly on cold mornings. i have replaced fuelpump,spark plugs ,coil, main air intake hose and
throttle switch. Can it be a faulty canck sensor. The car will also whilst driving cut out for a second or two and re-start again at times.
Jul 3, 2008 at 8:04 AM
DOCHAGERTY
  • 9,606 POSTS
These problems can often be challenging to deal with and often wind up being something quite simple, frustrating though they may be. Main and fuel pump relays, ignition switches, fuse blocks etc. If you send me a PM with your contact information, I will be in touch to see if we can get the car fixed. Regards,
Dr. Hagerty
Jul 3, 2008 at 10:19 AM
