1982 BMW 320
197,000 MILES • 4 CYL • 2WD • MANUAL
WHITTENCO
what all has to be done on a major tune up for a 1982 320i
Dec 3, 2008 at 7:03 AM
  • 31,937 POSTS
Hi there,
You should be checking and re adjusting the valve clearances, replacing the spark plugs, air & fuel filter, check the ignition leads for high resistance, check the distributer cap for cracks and tracking marks, check the rotor foe burning on the tip, check ignition timing, check belts, check that the exhaust manifold & flange are tight and not leaking, pressure test the cooling system. and while your at it change the engine oil & filter.
Mark (mhpautos)
Dec 3, 2008 at 7:26 AM
WHITTENCO
thank you very much for that ....................
whats all got to be done on emissions for my bmw 320i
Dec 5, 2008 at 6:20 AM
WHITTENCO
what do the specs have to be on the majior tune up and the emissions
Dec 5, 2008 at 6:25 AM
