My abs light is on...any suggestions...Thanks in advance!
Sep 21, 2007 at 5:40 PM
Have the ABS fault memory read to guide diagnosis, and check the brake fluid level, since low fluid can turn the ABS light on.
The owner of a 1995 BMW 318i reports that the ABS light is on and asks for suggestions. The expert advises reading the ABS fault memory and notes that low brake fluid can command the light on. Another user mentions possible brake sensor, disabled ABS, or voltage issues and plans to have the car checked.
