My abs light is on...any suggestions...Thanks in advance!
Sep 21, 2007 at 5:40 PM
DOCHAGERTY
✓Experienced Mechanic
you will have to have the fault memory read out
this will help guide the diagnostic
for example, the brake fluid level being low could command the ABS light on
repost and keep in touch
Sep 23, 2007 at 4:10 AM
BURROWSSJ
MEMBER
i read that it could be the sensor in the brake failing or could mean your abs is disabled i even heard that some voltage problem with 318's can cause this? i have the same problem, I am going to get it checked.
