2002 BMW 318 Two Wheel Drive Manual
I changed the FSR over the weekend and the problem is NOT fixed. The car is a 318i E46 right hand drive. Symptoms are - if the temp on the control panel is set to say 16 oC without air conditioning, the fan starts off low and as the car compartment gets warmer the fan starts to blow harder recahing top speed- I can see the light segment on the fan speed increase. If I then change the temp to say 20 oC the light segments start turning off and the fan slows down. When the heater was working properly when the set temp was reached the fan would only blow with one segment light on or at a very low speed. The other problem is when I turn on the air conditioning there is cold air from the face vents and warm air from the footwell and windscreen vents.
SPONSORED LINKS
Monday, June 9th, 2008 AT 7:04 AM
