2001 BMW 318 light steerring and high speed wobble
83,000 MILES • 4 CYL • 2WD • MANUAL
FASTR1UK
Hi experts ,, hope all is well
I have just bought 2001 2 door 318 bmw. steering feels dangerously light and i get a steering wobble around the 80mph mark. also when turning no feedback from steering to the the extent that it 'feels' like the front wheels are going to fold under the car. I did notice that the front left tyre is considerably more worn than the front right but dont think should make such a dramatic difference to what i believe is normally a very stable model. any advice much appreciated
Feb 3, 2009 at 9:11 AM
DOCHAGERTY
  • 9,606 POSTS
What was the outcome of the pre-purchase inspection, did it show up there? Worn tires can cause vibration at speed.
Feb 3, 2009 at 11:24 AM
FASTR1UK
unfortunately there was no pre - inspection, I only took it for a short test drive and didnt notice at that point. Could replacing the wheel also stiffen the sterering ?
Feb 3, 2009 at 5:48 PM
DOCHAGERTY
  • 9,606 POSTS
Which wheel are you referring to?
Feb 4, 2009 at 3:36 AM
FASTR1UK
Hi
I was referring to replacing the front left (when sat in drivers seat) tyre as this is considerably more worn than the right tyre ?
Feb 4, 2009 at 3:41 AM
DOCHAGERTY
  • 9,606 POSTS
Tire replacement could solve your problem, replace as a set and remember, your life is riding on the tires, dont go cheap here.
Feb 4, 2009 at 11:24 AM
FASTR1UK
thanks for the help .
had the tyre replaced and fixed the trackng ( which was way out ) . car is more stable now.
great site .. keep up the good work
Feb 5, 2009 at 7:24 AM
