Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
BMW
318
Engine Cooling
Water Pump
2000 BMW 318 water pump
2000 BMW 318
7,500 MILES • 4 CYL • 2WD • MANUAL
PSYCHO
MEMBER
1 POST
heating thermostat water circulation not sure if water is curculating through water pump how do u check if ur water pump is working thx
Jan 1, 2008 at 6:11 AM
DOCHAGERTY
Experienced Mechanic
mostly you assume that the pump is working unless there is a reason not to or if the pump is leaking then you would replace it.
Jan 3, 2008 at 1:39 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine overheating
