2000 BMW 318 RADIATOR COOLING FAN MOTOR!
160,000 MILES • 4 CYL • 2WD • MANUAL
BAKHROM
How to find out if there any problem with radiator cooling fan motor? Thank you... Buck.
Mar 10, 2008 at 7:02 AM
DOCHAGERTY
  • 9,606 POSTS
I am not sure what you need from us. If the fan is inoperative, it may be the final stage which will require replacing the fan. It may also be something in the control circuit. Scanning that system for fault codes would be very helpful.
Mar 11, 2008 at 6:03 PM
