1999 BMW 318 PO455 ON COMPUTER
108,708 MILES • 4 CYL • 2WD • MANUAL
FRASALA47
WE REPLACED THE MUFLER AND CATALYST BECAUSE WE WERE GETTING A BAD CATALYST CODE ON THE COMPUTER NOW WE SOLVED THAT
BUT WE ARE GETTING A PO455 WICH IS THE EMMISSION CONTROL APARENTLY HAS A LEAK ...
WHAT SHOULD I DO
Jul 10, 2008 at 12:01 PM
DOCHAGERTY
  • 9,606 POSTS
You may have left the fuel cap loose during a recent trip to the gas station, clear the fault and be sure the cap is tight. The fault code is for a gross leak detection and usually means you left the cap off or loose.
Jul 10, 2008 at 1:15 PM
