1998 BMW 318 ROUGH RUNNING
141,000 MILES • 4 CYL • 2WD • AUTOMATIC
FISHTUG
the engine lite is on but seemed to run fine until this a.m . at 3000rpm it only runs about 20 to 30 mph and jerks alot. the computer read out diagnosed an injector port to small possible air pump problem. air pump? a friend said it may be the mass air flow sensor.at 6000rpm it really runs bad and only 40mph. start with the sensor? thanks
May 23, 2008 at 2:31 AM
DOCHAGERTY
  • 9,606 POSTS
Have the faults read out and repost with your findings. I need to know exactly what the problem codes are.
May 24, 2008 at 4:34 AM
