1998 BMW 318 problem
1998 BMW 318
165,000 MILES • 4 CYL • 2WD • MANUAL
TOMAS19767
my car has a vibration around 2000rpm under power
Feb 1, 2010 at 7:43 AM
AUTOMD
  • 50 POSTS
I suggest taking it to a LR dealer and get them to pull all the engine codes. If all is OK, the next step you need to do is injectors. It's a common rail diesel and removal is a bit tricky, but if you pull them out, you will often be able to see a single injector with all the carbon deposits around it.
Feb 11, 2010 at 6:49 PM
