1998 BMW 318 overheating
78,000 MILES • 4 CYL • 2WD • MANUAL
MICWAY52
Hi, my bmw has a over heating problem,first of all the heater stopped producing any heat, so i changed the thermostat, that did'nt work, i have flushed out the radiator and there's no apperent leaks anywhere, the oil is clean, when i run the engine up to temperature the water blows out of the header tank, any idea's? thanks
Nov 6, 2009 at 8:34 PM
DOCHAGERTY
  • 9,606 POSTS
Was all the air out of the system?
Nov 7, 2009 at 5:09 AM
STEVEW84
  • 673 POSTS
Sounds like you got an air pocket in the system. BMW's are a PITA to get air out. Best way that I have found is leaving the reservoir cap on with it topped off with coolant. Run the car until it gets 3/4 hot then shut it off. Open the bleeder screw to get all the steam out then top off the coolant again. Keep doing this until it gets the air out.
Nov 7, 2009 at 5:21 AM
