1998 BMW 318 LF Window
1998 BMW 318
12,000 MILES • 4 CYL • 2WD • AUTOMATIC
TOM OD
The power widow regulator keeps ripping itself off the lower window track. It seems like when the window reaches the bottom, the regulator motor power does not cut off & the motor just stays on & bends the regulator arms until they pop off the rail. Is the regulator motor bad or is it the window switch?
Nov 3, 2009 at 5:22 AM
DOCHAGERTY
  • 9,606 POSTS
Did you replace the white plastic slider pieces?
Nov 3, 2009 at 3:19 PM
TOM OD
I did not replace the white sliders, they move freely & look OK. Also the lock pin fits tightly on the sliders
Nov 4, 2009 at 4:59 AM
DOCHAGERTY
  • 9,606 POSTS
I suggest replacement (of the sliders) and be very sure the ball ends are secure in the sliders, I usually get behind them with a pair of vice-grips and pop them in, it takes a fair amount of pressure to seat them.
Nov 4, 2009 at 3:17 PM
