1998 BMW 318 engine difference
KEVIN BEDDOE
Engine Mechanical problem
1998 BMW 318 4 cyl Two Wheel Drive Automatic
What are the differences between the M43 engine and the M44 engine
Mar 29, 2009 at 4:21 AM
DOCHAGERTY
  • 9,606 POSTS
Are you swapping motors or exchanging parts? The M-42, M-43, M-44 motors all shared the same inline four, DOHC design but valve actuation and balance shafts as well as several displacement versions makes for a lively combination, what did you have in mind?
Mar 29, 2009 at 7:28 AM
KEVIN BEDDOE
i am going to rebuild my engine, just awaiting the parts to land.i have already dismantled my engine so that when i get the bearings, i can get the crank cut to match the bearings.
Mar 30, 2009 at 1:29 PM
DOCHAGERTY
  • 9,606 POSTS
Good luck be with you my friend. ♥
Mar 30, 2009 at 4:55 PM
