1998 BMW 318 Brake grabs on right side
JSWEETWEST
Brakes problem
1998 BMW 318 4 cyl Two Wheel Drive 126000 miles
When I apply the brakes at any speed there is a sudden tug to the right for just a second. You can feel it in the steering wheel as it tugs.
Then it goes away and the brakes feel normal.
What could be the cause?
Aug 29, 2010 at 4:47 AM
ERNEST CLARK
  • 1,730 POSTS
Either your brake pads are worn unevenly or the rotors are warped.
Only a brake inspection will tell you this for sure. But as long as the "tug" only occurs during braking, then it's isolated to that system.
Sep 21, 2010 at 3:19 AM
