1998 BMW 318 1998 318Ti BMW ! inside a Gear Wheel comes
1998 BMW 318
FCROOS
Transmission problem
1998 BMW 318 6 cyl Two Wheel Drive Automatic 96K miles
When drive it drives fine, but when slow down it knocks with a Jerk in E - mode and also the ! mark inside the Gear wheel light comes. Hopefully it is a do with transmission, any recommended advice.
Apr 23, 2008 at 11:38 PM
DOCHAGERTY
  • 9,606 POSTS
Scanning the EGS system will uncover the fault. When that is completed, please repost with the fault.
Apr 24, 2008 at 2:23 AM
FCROOS
[quote:bcb95a4048="Dr. Hagerty"]Scanning the EGS system will uncover the fault. When that is completed, please repost with the fault.[/quote:bcb95a4048]
What is the EGS system, how to use it.
Apr 25, 2008 at 12:16 AM
DOCHAGERTY
  • 9,606 POSTS
The Electronic Gear Control module has faults and they can be scanned with proprietary software. You might have to go to the dealer or an independent shop with the right equipment. Use the telephone and the internet for finding these resources in your area.
Apr 25, 2008 at 11:51 AM
FCROOS
The Error Codes
153 CAN DME LOad Signal
115 Hot-film air-mass flow sensor
10 Oxygen Sensor upstream of catalytic convertor
Apr 28, 2008 at 9:45 PM
DOCHAGERTY
  • 9,606 POSTS
I would first replace the hot film sensor and the pre-cat 02 sensor, clear the faults and drive the car to see if this solves the problem. At 96k, the oxygen sensor is possibly biased towards the lean side. The load signal can be ignored at this time.
Apr 29, 2008 at 12:44 PM
