1997 BMW 318 Noise from the engine
110,000 MILES • 4 CYL • 2WD • MANUAL
KWAPPIAH
I have a BMW 318ti and the car's revs starts dropping when the engine heats up or i stop at the lights ie when idle. There is a loud whistling noise as well that comes from the engine and the whole thing shakes. There was a cat converter that rattled alot and i changed it but the is still happening. any help
Mar 7, 2010 at 11:42 PM
DOCHAGERTY
  • 9,606 POSTS
Replace part number 16 in the link I am sending you, it is the crank case vent valve, it is a high failure item, as are the hoses.
Mar 8, 2010 at 2:29 AM
