1997 BMW 318 brakes
142,000 MILES • 4 CYL • 2WD • MANUAL
MASTERVUDU
1997 bmwti. Do I need any special tools to replace the front/rear rotors and pads?
Mar 20, 2008 at 1:26 AM
MERLIN2021
  • 17,250 POSTS
Souldn't...sometimes you will see at the caliper mounting area, a thin metal bar, it is peened over to lock the bolts in place, use a hammer and chisel to unbend and flatten it, then use your 17mm socket to remove!
Mar 20, 2008 at 1:44 AM
