1997 BMW 318
BART6627
1997 BMW 318 4 cyl Two Wheel Drive
i replaced the motor in this vehicle and now the key will not start the car but i can start it under the hood with a starter button. can you tell me what my problem might be
Jul 17, 2008 at 4:22 AM
DOCHAGERTY
  • 9,606 POSTS
Check the trigger wire that goes to the starter, you may have not connected it. It may also be an EWS alignment issue, for this, you will need special software. There is also the neutral safety switch that may be disconnected. If you need more help, please repost with the VIN.
Jul 17, 2008 at 5:35 PM
