1996 BMW 318 what do i do??
ROCKAFELLOW420
Transmission problem
1996 BMW 318 4 cyl Two Wheel Drive Manual
hello my name is andrew
i need to know how to repair a syncroniser ring i think just before the slave cylnder came apart it would kick out of first gear it wouldnt evenm go in and if u let out the cluch in the gear it would just grind i just replaced the cluch pack and now am at an end and dont know what to doyou help is greatly appreacated
Nov 9, 2008 at 1:23 AM
  • 31,937 POSTS
Hi there,
The transmission will have to be removed and dismantled, there are special pullers and tools required to fully dismantle a gear box, so i would suggest that you purchase a work shop manual and study that section, often this is well beyond a home mechanic, so i would suggest that you make sure that you are confident before attempting this job.
Mark (mhpautos)
Nov 9, 2008 at 6:02 AM
DOCHAGERTY
  • 9,606 POSTS
Or consider a salvage yard for a replacement transmission. Call (619)444-2290 foe Autobahn dismantlers, talk to John or Sean
Nov 9, 2008 at 7:22 AM
