Engine Cooling problem
1996 BMW 318 4 cyl Two Wheel Drive 187000 miles
i have a 96` 318 TI automatic, has 187k on it...
-i just replaced the coolant temp. switch(fan switch) and the thermostat, my fan doesn`t come on and the car over heats at idle... the radiator and the hoses r LEAK FREE, the fan works when jumped, other than the high and reg. speed relays possibly needing replacement, should i look into a water pump of would there be evidence or failure such as noise ?
Feb 21, 2008 at 4:18 AM
