1995 BMW 318 water pump
DABIRDMAN31
Engine Cooling problem
1995 BMW 318 4 cyl Wheel Drive Type unknown Manual 220,00 miles
How do I remove and install the water pump for my 1995 BMW 318TI?
Mar 29, 2008 at 2:39 PM
BMRFIXIT
  • 19,053 POSTS
I believe it goes like this
you have to remove the 4 pulley bolts
remove drive belt remove pump 4 bolts remove pump
lube new O ring before installation
good luck
Mar 29, 2008 at 3:38 PM
DOCHAGERTY
  • 9,606 POSTS
If you have an issue with the pump then go to Amazon.com and get a Robert Bentley repair for your model car.
Mar 30, 2008 at 4:01 PM
