1995 BMW 318 starting problems
124,000 MILES • 4 CYL • 2WD • MANUAL
BODGER_89
i have a 318 on an 95 reg and it has a little trouble starting. takes around 5-7 seconds to start, if not longer. have just changed the coil pack, leads and spark plugs.
any ideas?
Aug 17, 2009 at 1:49 AM
DOCHAGERTY
  • 9,606 POSTS
It could be several items, I would check the crank case vent valve, they have a tendency to fail and cause the issues you are reporting. 11-15-7-501-567 is the part # and can be viewed at Realoem.com.
Aug 17, 2009 at 2:19 PM
