1995 BMW 318 key will not turn when putting it in igntion
PJONES62887
Computer problem
1995 BMW 318 Automatic 162000 miles
I had the car started went to turn the car off and the key came right out the ignition and the car was still running? i could not turn the car back off becuase they key will not turn the ignition the key only goes in and comes out. i had to turn the car off by taking the main fuse 15 i think out than the car shut off. what should i do? does the car need a tumbler or an ignition switch or can I fix the problem myself easily? It won't start because i can't get the key to turn so bringing it to a shop and not knowing what i exactly need is bad cause i dont want to not have enough money. any suggestions on what is wrong and what to do?
Nov 3, 2008 at 1:14 AM
DOCHAGERTY
  • 9,606 POSTS
The key assembly will need to be removed and the ignition lock will require replacement. It is a difficult task and might best be left to a professional.
Nov 4, 2008 at 6:44 AM
