As I tighten down draw down bolts water pump will not seat. Grease applied to O ring and at 1/4 turn per bolt I have snapped off one bolt hole on new Bosh pump. Even if 3 bolts will not hold the new pump on, which is my next goal. I will not buy a new pump unless I can install this one. There is no place to safely apply leverage and if the bolts do not draw it in without damage then what.
Aug 18, 2008 at 3:02 AM
