1994 BMW 318 turn signal
CLIPS1
Electrical problem
1994 BMW 318 4 cyl Wheel Drive Type unknown Automatic 135000 miles
hello! I HAVE A 94 BMW 318I ....THIS HAPPENDED YESTURDAY WHEN I WAS DRIVING I BUT MY RIGHT SIGNAL I HEARD THE CLICK CLICK NOISE U USUALLY HEAR WHEN U BUT UR SIGNAL BUT I DIDNT SEE THE LIGHTED ARROW SHOW UP IN MY DASH I PULLED OVER TO CHECK N SEE IF MY BLINKERS WHERE WORKING N THEY DID!! SO MY RIGHT BLINKER WORKS OUTSIDE BUT IT DOESNT WORK INSIDE (DASHBOARD) ANY CLUES PLLZZZ????IT WILL BE VERY MUCH APPRCIATED!!! THANXX
Dec 5, 2007 at 8:18 AM
DOCHAGERTY
  • 9,606 POSTS
The light bulb for the indicator is burnt out. the cluster can be removed to replace the bulb and they are available at most auto parts retailers. To remove the cluster there are Torx screws holding the cluster in and they are at the top edge of the cluster facing down. It is a tight fit to remove, you don't need to remove the steering wheel. replace the bulb and test before reassembly. repost if more assistance is needed
Dr.Hagerty
Dec 5, 2007 at 8:36 AM
