1994 BMW 318 trying to remove water pump
1994 BMW 318
138,000 MILES • 4 CYL • 2WD • AUTOMATIC
BLEUET6
have taken all the bolts off the pump I can see. In the manual they talk about taking off the thermostat housing but cam't see why it needs to be done. Does it? Because at this time I am stumped as the pump does not want to come out. Should it not come out when pulled on?
Thanks
Brian
Nov 9, 2008 at 12:48 AM
DOCHAGERTY
  • 9,606 POSTS
That pump may be stuck. Is it the original pump? If you got all the bolts out then it should come right out.
Nov 9, 2008 at 4:03 AM
BLEUET6
Well I saw a manual that one guy said to go to on line and it isn't the same as my car. There was 3 bolts in a triangle then one larger bolt. Cannot see any others but maybe I missed one. Will check again. DO I have to remove the thermostat housing?
Thanks
Brian
Nov 9, 2008 at 4:01 PM
