1994 BMW 318 Engine Thermostat
150,000 MILES • 4 CYL • 2WD • AUTOMATIC
GEILES
Hi, Have a overheating problem, need to know the location of thermostat on eng. Checked the normal location, radiator top hose engine end nothing there.
Jun 26, 2009 at 12:11 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Thermostat is in thermostat housing, located at the intake side of engine. Drain coolant then remove 3 bolts on the housing. Pull thermostat housing off and remove thermostat.
Jun 26, 2009 at 12:35 PM
