1993 BMW 318 Rear trailing arm
170,000 MILES • 6 CYL • 2WD • AUTOMATIC
COUCHGUY
I am trying to remove the trailing arm between the centre of the vehicle to the lower part of the hub area of the rear wheel. It somehow got badly bent, likely being towed out of a driveway last winter. I am not sure if the bolt in the centre of the car is is a nut and bolt or just a bolt, and it is very difficult to get at since the rear differential is only about an inch and a half behind it. Any suggestions on how to remove it would be appreciated! I was planning on heating the the bolt, but do not want to damage any bushings where this 'subframe' that goes up and around the differential. Thanks for your help!
Oct 19, 2009 at 12:35 AM
DOCHAGERTY
  • 9,606 POSTS
The bolt you are trying to get out will require the differential to be unbolted and pushed out of the way. The answer to your question,"is it a nut and bolt" is yes.
Oct 20, 2009 at 2:11 AM
