1993 BMW 318 my steering shakes alot
20,000 MILES • 4 CYL • 2WD • MANUAL
EROKSTEADY
i had run into a curb and had gotten a flat tire recently. i changed my tire but for some reason i can't go over 80 clicks. if i exceed 80 clicks the steering wheel starts to shake alot, it almost feels like the wheel is going to come off. at first i thought i didn't tighten the tire correctly but i checked and that wasn't the problem. i was wondering if you can give me an explanation as to what's wrong with my car?
Jan 16, 2008 at 1:11 PM
BMRFIXIT
  • 19,053 POSTS
[quote:790df63469="eroksteady"]Other Category problem
1993 BMW 318 4 cyl Two Wheel Drive Manual 200,00 miles
i had run into a curb and had gotten a flat tire recently. i changed my tire but for some reason i can't go over 80 clicks. if i exceed 80 clicks the steering wheel starts to shake alot, it almost feels like the wheel is going to come off. at first i thought i didn't tighten the tire correctly but i checked and that wasn't the problem. i was wondering if you can give me an explanation as to what's wrong with my car?[/quote:790df63469]
check the tire and balance
check rim
Jan 16, 2008 at 1:17 PM
