1993 BMW 318 e36 318is coupe has on engine compression?
RAW69
  • 9 POSTS
Engine Mechanical problem
1993 BMW 318 4 cyl Two Wheel Drive Manual 130,k miles
had local garage check my car as it has been off the road for a year now due to non start problem.as i have written to you in the past about my sick car it turns out that i have no compression,i have fuel,spark and motor cranks fine.do you guys have any clues or solutions to fix this problem.is it a timing issue,or do i have to remove head again to check for damage to the valves.hopefully not the later: ([img:453c997d2c]http://www.2carpros.com/forum/automotive_pictures/206424_misce36photos06_1.jpg[/img:453c997d2c][img:453c997d2c]http://www.2carpros.com/forum/automotive_pictures/206424_misce36photos06_2.jpg[/img:453c997d2c]
Sep 16, 2008 at 7:15 PM
DOCHAGERTY
  • 9,606 POSTS
Has a leak down test been performed? Where is the compression going? Is it leaking past the valves or the rings? What has been done to the car in the past? What is the Vehicle Identification Number please.
Sep 17, 2008 at 2:32 AM
RAW69
  • 9 POSTS
i have done overhaul to engine due to car overheating because of bmw`s plastic radiator neck which cracked.so head is new,valves new,head gasket new, All gaskets in engine are new.car was running fine for about 6 months then it just shut down while driving on the motorway,when i got i home, i removed timing chain cover to find guide for timing chain was completely broken (more bmw plastic) so i wondered if timing had jumped some how.i used timing tools to check timing but still i have this no start problem :( would the V.I.N help you seeing this is a euro spec car?
https://images.2carpros.com/forum/automotive_pictures/206424_misce36photos06_3.jpg
Sep 17, 2008 at 7:45 PM
DOCHAGERTY
  • 9,606 POSTS
If the cam chain and/or the timing is off then you might need to pull the head back off to get it right again.
Sep 18, 2008 at 11:18 AM
RAW69
  • 9 POSTS
hi again,thanks for your input and advice.when i get my car back from garage depending whether i let them complete the work on the car(it`s all about the money they want to do the repairs) i will have to put a few days aside to strip engine and head to check for damage to valves ect. then re-build the bloody thing ;( thanks again... million dollar question, "why oh why,do bmw have to use so much plastic in their engines?
https://images.2carpros.com/forum/automotive_pictures/206424_misce36photos06_1.jpg
https://images.2carpros.com/forum/automotive_pictures/206424_misce36photos06_4.jpg
Sep 18, 2008 at 7:22 PM
