1993 BMW 318 cam timing set up and marks
JOHN CHRISTIE
Engine Mechanical problem
1993 BMW 318 4 cyl Two Wheel Drive Manual
Had a head rebuild and now need to set cam belt to cam gear,I need to find correct timing marks
Nov 9, 2009 at 6:33 AM
DOCHAGERTY
  • 9,606 POSTS
Chain, not a belt. There is a special tool needed for the camshafts. It holds them in correct timing. I will get the number of the tool today and get back to you. Also a procedure.
Nov 10, 2009 at 12:32 AM
