1992 BMW 318 BMW 318is clutch problem
HULLMAN
1992 BMW 318
Hello
I parked my car outside and in the morning i went into my car and pressed the clutch and it went down with any resistance.
At night it was below 0 degrees and the clutch got iced i think.
I have enough fluid in the tank.
How can i deforst it without taking it apart ?
Is it enough when i push it into a garage ?
Jan 25, 2009 at 2:10 AM
DOCHAGERTY
  • 9,606 POSTS
As I understand you, the pedal went to the floor and stayed there. The problem is most likely a failed hydraulic cylinder, either the master or the slave will require replacement, perhaps both. Brake fluid has agents in it that help absorb water so freezing is usually not a concern.
Jan 25, 2009 at 2:58 AM
