1991 BMW 318 temperature
1991 BMW 318
142,000 MILES • 4 CYL • 2WD • MANUAL
KEVDONALD1969
my temperature gauge went to red and after filling with kettle and half of water it returned to normal.after driving for a while the temperature gauge flunctuates between middle and red all the time
May 19, 2008 at 8:29 PM
  • 31,937 POSTS
Hi there,
If you are loosing coolant. you will need to get a system pressure test done, this will help locate any external leaks. have the thermostat changed and get the radiator cleaned & flow tested.
Mark (mhpautos)
May 19, 2008 at 9:39 PM
