1991 BMW 318 Gas tank removal and replacement
CRUSTY
1991 BMW 318 4 cyl Two Wheel Drive Manual
How do I remove the tank. It looks like I have to remove the drive shaft? Looking for a diagram or video to help.
Jun 13, 2010 at 2:55 AM
DOCHAGERTY
  • 9,606 POSTS
Fuel tank removal requires having the driveshaft out as well as exhaust, detach wiring and fuel supply and return lines from the top access ports, drain the tank to allow easy handling, and out it comes. Here is a link to an exploded view: http://www.realoem.com/bmw/showparts.do?model=BE53&mospid=47480&btnr=16_0314&hg=16&fg=05
Jun 13, 2010 at 3:12 AM
