1985 BMW 318 ignition switch
130,000 MILES • 4 CYL • 2WD • MANUAL
MATER420
how do you change the ignition switch
Jan 12, 2010 at 3:36 AM
  • 75,988 POSTS
REMOVING AND INSTALLING STEERING LOCK/IGNITION SWITCH : *Disconnect battery ground lead. *Remove steering wheel. *Remove instrument panel trim at bottom left. *Remove lower steering column casing section.
https://images.2carpros.com/forum/automotive_pictures/12900_ignition_1.jpg
*Press in hooks on both sides toward ignition switch and pull out the ignition switch. Installation : *Check position between ignition switch and steering wheel lock!
Jan 12, 2010 at 4:38 PM
