1984 BMW 318 Turn Signal
TEGGYGSR_93
  • 19 POSTS
Electrical problem
1984 BMW 318 4 cyl Manual 157397 miles
I have a 84 318i that runs perfect. I havent drove it in 2 weeks because of a vacation I took. Now that I am back, the turn signals dont work but the hazard lights work, any idea, plus the wipers wont work either.
Jun 11, 2010 at 9:39 AM
BLUELIGHTNIN6
  • 16,542 POSTS
turn signal (multi function) switch most likely the culprit, first check fuses and signal flasher relay
Jun 11, 2010 at 11:06 AM
DOCHAGERTY
  • 9,606 POSTS
The wipers may need the wiper relay to be replaced, its the long black rectangular plug in inside the fuse box.
Jun 11, 2010 at 4:19 PM
TEGGYGSR_93
  • 19 POSTS
Thank you guys. I have one last problem that I just noticed, my brake lights dont work either, any guess?
Jun 15, 2010 at 4:33 AM
BLUELIGHTNIN6
  • 16,542 POSTS
brake light circuit runs through the turn signal switch as well so once replaced they should work again
Jun 15, 2010 at 5:23 AM
TEGGYGSR_93
  • 19 POSTS
thank you, you have been very helpful. I checked all the fuses and the are good, so since they still dont work, where wold the turn signal switch be located?
Jun 15, 2010 at 7:11 AM
BLUELIGHTNIN6
  • 16,542 POSTS
the turn signal switch is the switch you use to operate the signals on and off
Jun 15, 2010 at 9:43 AM
DOCHAGERTY
  • 9,606 POSTS
Brake lamp switch is faulty, replace it.
Jun 15, 2010 at 3:28 PM
TEGGYGSR_93
  • 19 POSTS
well i have checked the relay and its clicks and works when i turn on the hazards & all fuses are good, the high beams work and they are connected to the turn signal switch as well, so with those working and the signals not working, is the problem most likely the signal switch?
Jun 18, 2010 at 4:27 PM
DOCHAGERTY
  • 9,606 POSTS
Yes.
Jun 19, 2010 at 3:36 AM
