1984 BMW 318 SPEEDOMETER
1984 BMW 318
223,358 MILES • 4 CYL • 2WD • MANUAL
TPIJOE
PLEASE HELP ME DIAG. SPEEDO NOT WORKING. VSS @ REAR IS NEW AND SHOWS ON-OFF-ON-OFF W/OHM METER WHERE DO I GO NEXT? ARE THERE ANY COMMON FAILURES?
Apr 2, 2008 at 11:15 AM
DOCHAGERTY
  • 9,606 POSTS
Yes there is a common issue with E-30 instrument clusters. The driver chip fails and the remedy is either seeking out a speedo/tach repair service or outright replacement of the speedo and or the cluster and or the service interval board (the narrow circuit board with the nicad cells soldered to it) I would start with a visual inspection of the disassembled instrument cluster and go from there.If the batteries are old and leaking the service interval board will require replacement. Repost to me or send a PM if more assistance is required.
Apr 3, 2008 at 5:32 AM
