1983 bmw 318i
EYEFIXIT
  • 5 POSTS
I HAVE A 83 BMW 318I, THE MILEAGE IS 256609, AND THE ENGINE SIZE IS 1.8, TAKES 6 TO 8 TIMES TO START, ONCE RUNNING IDLES BAD.TESTED FUEL PUMP AND TESTED FUEL INJECTORS, 5 INJECTOR ON THE INTAKE WHEN APPLIED VOLT SKITS AND WHEN TURN KEY WILL START BUT CUTS RIGHT BACK OFF.
Oct 24, 2007 at 10:08 AM
EYEFIXIT
  • 5 POSTS
[quote:3e93d69928="eyefixit"]I HAVE A 83 BMW 318I, THE MILEAGE IS 256609, AND THE ENGINE SIZE IS 1.8, TAKES 6 TO 8 TIMES TO START, ONCE RUNNING IDLES BAD.TESTED FUEL PUMP AND TESTED FUEL INJECTORS, 5 INJECTOR ON THE INTAKE WHEN APPLIED VOLT SKITS AND WHEN TURN KEY WILL START BUT CUTS RIGHT BACK OFF.[/quote:3e93d69928]
Oct 24, 2007 at 10:16 AM
