2001 BMW 316 Engine Light on
80,000 MILES • 4 CYL • 2WD • MANUAL
HONEYHAMPERS2
A yellow light showing an engine symbol has appeared on the dashboard - it is a solid light not a flashing light - can you advise on what might be causing this
Jan 5, 2009 at 10:18 AM
DOCHAGERTY
  • 9,606 POSTS
The check engine light can be commanded on for several reasons. A loose fuel cap, a sensor showing a plausibility fault, or some emissions related issue. A sczn of the car from the OBDII port is in order.
Jan 6, 2009 at 3:44 AM
