Whistling Noise on rundown and at idle
1999 BMW 316
151,000 MILES • 4 CYL • 2WD • MANUAL
STEVENMAC
Hi.... I am experiencing a high pitched whistle in my 99 E46 BMW 316i 1.9. It happens once the car warms up after 20 miles or so.... It disappears if you fully press the accelerator but is louder as the car comes down to idle speed. Already changed the idle regulator at the advice of a shoddy mechanic who lied to me that he had fixed the problem. Please please please help... this noise is ruining my life... my vin is aw52308
Aug 31, 2008 at 3:34 AM
DOCHAGERTY
  • 9,606 POSTS
It sounds like you have a vacuum leak which will make that noise. Here is a guide to help you find it.
It can be the crankcase ventilation system causing it as well.
Please run down this guide and report back
Cheers
Aug 31, 2008 at 5:04 AM
HUSSAIN54
hello, i am also experiencing the exact problem with my BMW 316. I have gone to three or four mechanics and everyone has diagnosed different problem. Kindly tell me how have u rectified it and what was the exact cause. Thanks
Jul 28, 2012 at 3:31 PM
DOCHAGERTY
  • 9,606 POSTS
11157501567 is the part you need, it is the crankcase vent valve #16 in the diagram below.
Cheers
Oct 25, 2012 at 11:27 PM
