1996 BMW 316 Fuel problem
RICARDO17
Engine Mechanical problem
1996 BMW 316 4 cyl Two Wheel Drive Manual 90.000 miles
I have a bmw 316 compact and as i was driving it the engine cut out then restarted then cut out again.I have checked the spark plugs which are in good condition and working i suspect a fuel problem even though the tank is a quarter full help.
Jan 1, 2010 at 2:13 AM
  • 75,988 POSTS
Check the fuel pressure with a fuel pressure gauge if it's within specs and also check the injectors if they are pulsing.
Jan 1, 2010 at 11:09 AM
