1992 BMW 316
142,000 MILES • 4 CYL • 2WD • AUTOMATIC
LEEG1
every time i brake at a stop light or an intersection my car goes into neutral for about 5 seconds , i go to pull away and the car jerks into gear it only does this when i brake hard the car has an automatic gear box,thank you
Oct 24, 2008 at 10:53 AM
DOCHAGERTY
  • 9,606 POSTS
Service the transmission and change the filter then be sure the fluid level is correct, you show signs of low fluid level in the transmission. ♥
Oct 24, 2008 at 11:02 AM
