Bluetooth not activated
60,000 MILES • V6 • 2WD • AUTOMATIC
NASHWAN GULLI
Bluetooth not activated on the screen when I touch it nothing happens.
Oct 5, 2018 at 3:04 AM
  • 55,746 POSTS
Here are the instructions for the Bluetooth sync:
Bluetooth Pairing For Vehicles With Radio RPO: UF7
Either reset the pin code on the radio to 0000, or go under Device Info on the radio and see what the pin code is (to enter it later on the MIT).
Turn the BT discover-able ON in the radio Bluetooth settings.
Press Pair Device on radio (DO NOT PRESS SEARCH BLUETOOTH DEVICES ON THE RADIO).
Press the Pair button on the MIT.
When the three LED lights begin flashing on the MIT, enter the pin code (either 0000 if you reset it to that or what the radio pin code was).
MIT will then automatically connect with the radio and should show "MIT Connected" message.
Make test call and the audio streaming test.
Holden Radio Bluetooth Pairing Instructions
Using the radio controls, place the radio into "Discoverable Mode".
Place the MIT into Bluetooth mode by pressing TEST SELECTOR until the Bluetooth LED is illuminated.
With the MIT in Bluetooth mode Press and Release the #1 button (the Bluetooth LED will begin to slowly blink).
Now Press and release the PAIR/CALL button on the MIT (the Bluetooth LED will begin to blink a little faster).
On the radio Enter the PASSKEY when prompted: (press "0000" then Press "OK").
The MIT and radio will PAIR and CONNECT (the Bluetooth LED will be Fast Flashing).
Use as regular MIT at this point.
Cheers, Ken
Oct 7, 2018 at 4:47 AM
