my Bluetooth is always hooked up even when I am playing the radio?
190,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
MROULET1
  • 79 POSTS
For a while I noticed that my Bluetooth is always hooked up even when I’m playing the radio. If I’m on my phone I can’t hear anything because it’s hooked up. I understand that it has to be connected but it used to do that.
Now it’s started to not hold a Bluetooth connection. It drops a lot now. So, I started using my USB and when the Bluetooth connects again sometimes you can’t hear anything because it’s connected to Bluetooth.
Aug 22, 2024 at 4:21 AM
  • 55,594 POSTS
conflicts between Bluetooth and USB - are fairly common in older vehicles as their Bluetooth systems start to age.
1. Reset the Bluetooth System
2. Delete Paired Devices
3. Reset the System: In some cases, resetting the car's Bluetooth module can help.
4. Clear Phone Cache and Data
5. Disable Auto Connect (if possible)
I would do a hard system reboot which will restart the system, here is a guide to help you fix it:
https://www.2carpros.com/articles/step-by-step-guide-performing-a-hard-system-reboot-for-your-vehicles-electronics-systems
Please go over this guide and get back to us.
Aug 22, 2024 at 5:17 AM
