blueish smoke when going full throttle
52,000 MILES • 2.0L • 4 CYL • FWD • AUTOMATIC
TENNBANDI
need to change pcv valve but can not find it location on intake
Jan 20, 2015 at 9:25 AM
CARADIODOC
  • 34,403 POSTS
It's screwed into the cylinder head cover. All you can see of the valve is the hex nut. If you have the new valve, you'll see what that nut looks like. There's a hose going to it too that angles down and goes between two intake manifold runners.
Jan 20, 2015 at 10:00 AM
