Blue smoke?
80,000 MILES • 2.0L • TURBO • 2WD • MANUAL
SIMONJOHNSON445
Can't see apparent leak from engine just usual dirt. Blue smoke from exhaust, more when accelerated. No milking color in oil do need filter changed and wondering if it could be cause of burning?
Jul 15, 2023 at 6:59 AM
  • 110,248 POSTS
If you run the engine with dirty oil for an extended period of time, it will cause wear quicker to the engine. However, if this is one time, that wouldn't cause it.
How much oil is it using? Also, if there are no external leaks, check the PCV valve to make sure it is good. Also, if you are only seeing blue smoke under acceleration, it could also be valve seals.
Let me know. Also, this vehicle isn't offered in the US, so I have nothing in my manual related to oil use.
let me know what you find.
Jul 15, 2023 at 4:10 PM
